siilver
Message 1 of 32
why bt??speed
how come bt cant give me any reason why iv lost 5mb of internet speed in no time
one day i had over 7mb and now im lucky to get 2mb
iv had a bt guy out to have a look at it and all, and he has put in for some sort of reset, told it would take 4hour, no joy, phone up, they say after the 4hours it would take 48 hours to balance, quess what still no luck
so i asked the guy on the phone to night  how come iv looks the 5mb, he never really answered, but said the downstream is 8mb, that means your downloading speed will be 1.5-2.5mb
so i cant understand how iv had 7mb for a few years now
heres my specs
Line stateConnected
Connection time0 days, 3:51:46
Downstream8,128 Kbps
Upstream448 Kbps
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeFast
Noise margin (Down/Up)12.8 dB / 24.0 dB
Line attenuation (Down/Up)7.0 dB / 4.0 dB
Output power (Down/Up)11.8 dBm / 12.0 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)8 / 2147480000
HEC Errors (Down/Up)nil / 4
Error Seconds (Local)6
31 REPLIES 31
Message 2 of 32
Re: why bt??speed
suggest you run a bt speedtest speedtester.bt.com and when completed post the results back here as they will help with your speed issues
siilver
Message 3 of 32
Re: why bt??speed
Download speedachieved during the test was - 1762 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps
Message 4 of 32
Re: why bt??speed
stats look good with 8mb connection being max speed for adslmax.  your connection time is <4hrs suggesting resets/disconnections. was this done by the hub was did you try some resets in the hope your connection would come back to normal?  as john46 requested the btspeedtester will probably show a low profile due to the resets
geebuss
Message 5 of 32
Re: why bt??speed
your ip profile is currently sitting at 2000 so your not going to get more than you are at present wait for 2 more days for your profile to rise with sinc speeds and then run the test again
siilver
Message 6 of 32
Re: why bt??speed
the guy in the call centre told me to reset the hub
Message 7 of 32
Re: why bt??speed
if you just stay connected 24/7 for 3/5 days then your profile will come back to 7150
siilver
Message 8 of 32
Re: why bt??speed
cool thanks
siilver
Message 9 of 32
Re: why bt??speed
still no incase of speed, its been a few months now and still the same slow speed
how can it go from 7mb to 1.2mb?
Message 10 of 32
Re: why bt??speed
can you post your stats again and runbtspeedtester and post results
if your profile is still 2000 and your connection time is 3+ days then you should email the mods as your profile is stuck
http://bt.custhelp.com/app/contact_email/c/4951
