Message 1 of 5
why???...
http://www.speedtest.net/result/2023868089.png
why am i getting this result throught bt infinity option 2 ?
speedtest done through a wired connection from my laptop to the homehub3
activation date was 12 june 2012
4 REPLIES 4
Distinguished Expert
Message 2 of 5
Re: why???...
its been acknowledged as a problem by bt, one solution may be to replace the hh3 with something else
Message 3 of 5
Re: why???...
and where did you get this solution ?
Expert
Message 4 of 5
Re: why???...
theres a known problem if you look here http://community.bt.com/t5/BT-Infinity/Infinity-drops-below-1M-bits-each-day/td-p/524839/page/10 it will work fine on wireless. problem will be sorted via a firmware upgrade within a few days
Expert
Message 5 of 5
Re: why???...
My old homehub used to do this often HomeHub type B, Just go to bthomehub.home login and disconnect/reconnect and the issue will be fixed. This seems to be the best way to fix the issue without causing DLM to lower your connection speed.
