collectors
Message 1 of 2
wifi problems
Hi, hope you can help?
                              i am constantly getting my wifi dropping out or not comunicating with devices around the bungalow.
I have the BT Home Hub 3.0 sited in the center of my loft & some of the wifi products i have are only 6 to 8 feet away with only a plaster board ceiling between them. (Not foil backed).
I have 2 wifi radios that keep dropping out & some LightwaveRF products that sometimes work & sometimes dont.
Would it help to purchase the new BT 5 hub????
1 REPLY 1
Keith_Beddoe
Message 2 of 2
Re: wifi problems
Welcome to this forum.
I don`t think the new hub would help, and it may even be worse, from what has been reported on this forum.
It could be interference especially if you have the home hub well above ground.
There are some suggestions on this page which should help.
Wireless problems and things you can try, to resolve them
Look at the bit that refers to the wireless channel.
There are other suggestions on this main page.
Wireless connection problems
