DavidBrent
Message 11 of 13
Re: wireless adapter can't see HH3
Hi garethaj, this sounds very similar to the problem i had going from HH1 to HH3.  See my post http://community.bt.com/t5/BB-Speed-Connection-Issues/That-old-chestnut-of-not-connecting-correctly/...
garethaj
Message 12 of 13
will have a look at n vs g / b
not sure re encryption - will check
yes can see a number of other networks and can still see HH2 when i plug that back in
abhisheksax
Message 13 of 13
if u hav an ethernet cable (the one with yellow ends), connect it between ur computer and HH3. Change the channel to 11 and wireless type from 802.11b/g/n to 802.11b/g. then go to network connection from Control Panel and disable and reenable the wireless network connection....search for wireless networks and connect to the HH3...it will definitely work...trust me
Abhishek Saxena
