helzapoppin
Message 1 of 3
wireless dongle for hub 4
my mate hes just got his bthub 4 but his laptop needs a wifi dongle to bring it up to the latest spec which bt dongle do we need. also can we set it up with a ethernet cable so he can use it now.
2 REPLIES 2
Keith_Beddoe
Message 2 of 3
Re: wireless dongle for hub 4
It should connect with the existing laptop wireless card unless its very old.
You can connect using Ethernet if you want.
The most suitable adapter for an older laptop would be this one.
http://www.shop.bt.com/products/bt-dual-band-wi-fi-dongle-600-075715-8W45.html
helzapoppin
Message 3 of 3
thank you for reply keith-b
