tim86
Message 1 of 21
wireless printer not working since changing broadband
having recently chagec to home hub 3 i can no longer use my wireless printer on my laptop or tablet the printer is HP deskjet 3050A has anyone any suggestions or solutions on how to fix this annoying issue?
20 REPLIES 20
john46
Message 2 of 21
Re: wireless printer not working since changing broadband
have you changed the wireless security code on the printer as changing the hub will change the code
tim86
Message 3 of 21
thanks for the reply how do i change the code?
imjolly
Message 4 of 21
enter 192.168.1.254 in your browser then the admin password then go to wireless where you can change the wifi password or you can enter your printer setup and try and connect to new router ssid and then enter password which is on the pullout tab in the HH3
tim86
Message 5 of 21
this hasnt worked any other ideas?
Keith_Beddoe
Message 6 of 21
Something here might help Wireless Help
Either that, or go back to using your old home hub.
imjolly
Message 7 of 21
does your printer see the HH3 ssid?  if so when you try and connect it asks for the password which is on the pullout - just enter password and connect
tim86
Message 8 of 21
thanks for the advice i can now print wireless from my phone and tablet but not my laptop any suggestions on how to fix this issue?
Keith_Beddoe
Message 9 of 21
Which suggestion has worked so far, its not clear?
tim86
Message 10 of 21
sorry i'm not technical minded alli need to do now is get my printer online on my laptop
