Keith_Beddoe
Message 11 of 21
Re: wireless printer not working since changing broadband
What I meant was, which advice fixed the problem, what did you do?
tim86
Message 12 of 21
reset the hub and switched everything off and back on now the printer on my laptop is offline thanks for being patient
Keith_Beddoe
Message 13 of 21
Why can`t you just use your old home hub, the HH3 has a number of problems?
tim86
Message 14 of 21
dont have it anymore put it in the bin
john46
Message 15 of 21
Try uninstalling the printer from your laptop then reinstalling it that some times solves the problem
Keith_Beddoe
Message 16 of 21
I hope you took it to your recycling centre and not just put it in the bin !!!
Can you change your printer settings so that it uses a static IP address?
What is the make and model of the printer?
tim86
Message 17 of 21
its a hp deskjet 3050A it went to my local recycling plant
Keith_Beddoe
Message 18 of 21
I have looked at the manual, there does not appear to be any option to set a static IP address. You may be able to persuade the home hub 3 to always use the same address.
There is another thread about this same printer and other devices not working with the HH3.
http://community.bt.com/t5/BB-Speed-Connection-Issues/HH-3-and-Mac-OSx-issues/m-p/155589/highlight/t...
You may have to connect the printer using USB, or get another home hub 2.
tim86
Message 19 of 21
thanks for all the advice kieth but im set up and all working many thanks for your time and effort
Keith_Beddoe
Message 20 of 21
Must have been just a fleeting problem.
