feline34
Message 1 of 13
wiring and the master socket
Hi All,
can anyone tell me who owns what with ref to the wiring and master socket.
Does Bt own the wiring up to the master socket?
Do I own the wiring after the master socket?
We have had Bt out now 4 times to fix the same fault, we have not been charged, each time they have been they have just touched and cut the wires by the junction box which is outside the house.The last time they came the put a new box outside and also put a small junction box just inside the garage.We live in a town house so the master socket is on the first floor so I Am guessing that the trouble is with the wiring. This is the the wiring before the master socket. Will I be charged for this wiring if it needs replacing?
12 REPLIES 12
Message 2 of 13
Re: wiring and the master socket
You are responsible for all wiring after the master socket Openreach are responsible for all wiring up to the Master socket
Guru
Guru
Message 3 of 13
Also, If you have a box that looks like this:
Then Openreach are responsible upto this grey Openreach box and your responsible for all the wiring after it.
The box is usually found outside. They have recently started to be used so you may not have one but have a master socket instead.
Hope that helps.
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
plainview
Recognised Expert
Message 4 of 13
@jac_95
Openreach started installing External NTE's about 6 years ago and stopped installing them about 5 years ago for two main reasons;
A. They are not compatable with FTTC Broadband
B. Property Developers could never quite grasp that Openreach were only responsible upto the grey box outside and none of the internal wiring/sockets, not even the first socket that entered the property from the external NTE.
I worked for repair complaints at the time and the absolute hassle those things caused on new build sites was a nightmare.
feline34
Message 5 of 13
Box out side is just a junction box, that is a box with a cover with a couple of joined wires. Does not look like the pic above.
box in garage two feet away is just a junction box about the size of a match box.
Then upstairs to the white master box which has the words open reach on it, it has the plate you take off to reveal the test socket
good comments so far and is what I thought.
Distinguished Guru
Message 6 of 13
Although openreach are responsible for the wiring up to and including the main socket any damage to this cabling on your premises by you there would be a charge by openreach for the repair.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Liam4503
Message 7 of 13
Can I ask as to who is responsible for the master socket itself?
reason I ask is that my phone line stopped working in August a couple of months after I had infinity installed. The engineer put in a new master socket at the time.
an openreach engineer came out and replaced the faceplate of master socket and everything worked properly.
2 months later I've now been billed £99 for the engineer visit. Doesn't seem right or fair as the fault was with master socket.
Message 8 of 13
no that is not right
I suggest you contact the forum mods they should be able to get this problem sorted for you this is a link to them http://bt.custhelp.com/app/contact_email/c/4951
They normally reply by email or phone directly to you within 3 working days they will take personal ownership of your problem until resolved and will keep you informed of progress
They are a UK based BT specialist team who have a good record at getting problems solved
This is a customer to customer self help forum the only BT presence here are the forum moderators
Liam4503
Message 9 of 13
Thanks for the reply, email sent.
Message 10 of 13
post back with how you got on as it will help others
