Paulmini
Message 1 of 5
wont let me register 2nd device
I can't register 2nd device, keep getting error code TVE_P933.  I have tried uninstalling app.
4 REPLIES 4
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 5
Re: wont let me register 2nd device
welcome @Paulmini
There are a few different apps  eg BT TV , BT TV Purchases , BT Sport , Youvierw App .
I suspect you are referring to the BT TV app - is that correct ?
If so there is this help page which might be of use
http://bt.custhelp.com/app/answers/detail/a_id/51209
Paulmini
Message 3 of 5
Many thanks for the replay. Yes i do mean the BT TV app and it seems there was a issue with removing devices.
Gemma_P
BT TV Expert
Message 4 of 5
Hi @Paulmini
Did the problem get resolved, with the removing devices? Or are you still having issues?
Paulmini
Message 5 of 5
Hi Gemma_P
Fingers crossed it's all sorted.  They deleted them there end,  on my box it was showing no devices.  I now just need to wait until the 1st February to add a new device. If it doesn't work I will come back to you.
Paul
