bahtatter
Newbie
Message 1 of 2
xbox 360 severe lag
Hi played xbox 360 for ages, for some reason in the past week its become unplayable (lagging really bad) i am on a bt hub 3. I have turned on and off and reset, still lagging. Any ideas? Please answer in plain english not very tech savvy cheers!
1 REPLY 1
Malacath
Expert
Message 2 of 2
Re: xbox 360 severe lag
Are you using a wired or wireless connection?
If you are using wireless then it could be wifi interference.
So try changing the wireless channel.
Go into the hub settings by typing bthomehub.home in the address bar of your web browser. If that doesnt work type 192.168.1.254
Go to advanced settings then wireless settings. If it asks for a password the default one is on a sticker on the hub.
In wireless setting find the wireless channel and change it. Its best to try channels 1, 6 or 11. if those channels dont help then use ones inbetween.
once youve changed the channel try your xbox again. keep trying different channels until you find one that works.
