juststev
Newbie
Message 1 of 2
xbox one high latency
Hi there,does anybody out there know how to bring down the latency?mine is currently running at 152 ms.This is quite high for xbox live mutiplay,does anyone have a solution?
1 REPLY 1
Ravenholm
Message 2 of 2
Re: xbox one high latency
The Xbox one test pings a server in Seattle, best thing to do is go to speedtest.net on your laptop/PC and then choose a server in seattle then match the results up. If the xbox one is a lot slower then there is a problem but i'll bet it'll be round abouts the same.
