ktnch
Message 1 of 5
yet again connection drops !!!
after the last fix speed was ok for a few months but now gone back to the same old **bleep**. Speed dropping to around 0.06mb having to restart modem cant do anything with broadband at all !
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):4.1 dB / 21.0 dB
Line attenuation (Down/Up):45.6 dB / 22.5 dB
Output power (Down/Up):20.4 dBm / 12.1 dBm
FEC Events (Down/Up):176707827 / 443
CRC Events (Down/Up):90654 / 432
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):295118 / 488
Error Seconds (Local/Remote):5351 / 673
4 REPLIES 4
ktnch
Message 2 of 5
Re: yet again connection drops !!!
he above was only after 1 dayand 3 hours
Connection Information
Line state:Connected
Connection time:1 days, 03:13:52
Downstream:4.906 Mbps
Upstream:448 Kbps
ktnch
Message 3 of 5
spRe: yet again connection drops !!!
speed test result the bt one would not work
http://www.broadbandspeedchecker.co.uk/bimages/120744031.jpg
Keith_Beddoe
Message 4 of 5
Re: spRe: yet again connection drops !!!
Are you connected using an Ethernet cable, direct to the home hub?
ktnch
Message 5 of 5
wired and wireless, newist lappy is 1 month old the network cards in all the wireless lappys pcs are all "N" cards, even the kids wii or xbox keeps getting booted from the net, we used to have an acutal download speed of 5mb now its half of that yet again
must of restarted it self today at some point again
ADSL Line Status
Connection time:0 days, 07:07:20
Downstream:4.5 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):7.8 dB / 20.0 dB
Line attenuation (Down/Up):45.7 dB / 22.5 dB
Output power (Down/Up):20.0 dBm / 11.9 dBm
FEC Events (Down/Up):11781936 / 31
CRC Events (Down/Up):2250 / 29
HEC Events (Down/Up):54586 / 29
Error Seconds (Local/Remote):2399 / 24
Connection time:0 days, 07:07:59
Downstream:4.5 Mbps
Upstream:448 Kbps
