JohnWinter
Message 1 of 6
(yet another?) Infinity Speed Query/Issue
Hello folks
Seems like many of you have had success when asking for help on the forums, so here goes.
I had infinity installed in January this year - the engineer took around an hour to complete the job, and my line profile was initially set at around 35mbps, (on a 500m line) and I was getting mid 30mbps dowloads on btspeedtest and speedtest.net, and around 10mbps uploads. Great!
However, over the past few months I've seen some problems. My home hub and modem have needed resets to reconnect to the internet (the modem is mounted on the wall vertically, before you ask...), I've noticed both declining upload and download speeds, my profile has  reduced to 27mbps, and my download speeds are now in the mid twenties. Today I ran btspeedtest and came up with the following results on test3...
But on speedtest.net, still at mid twenties.
So my questions are:
Can either speedtest.net or btspeedtester be trusted - I do appreciate peak speeds and so on can be affected by traffic and contention but why such a difference?
Do I have a connection problem as indicated by btspeedtest?
Can I restore my initial speeds by requesting a line profile reset?
Thanks in advance for your help
5 REPLIES 5
JohnWinter
Message 2 of 6
Re: (yet another?) Infinity Speed Query/Issue
Bump for the Mods - is there any mileage in getting my line profile reset to restore previous speeds?
Message 3 of 6
Try www.speedtest.bbmax.co.uk
JohnWinter
Message 4 of 6
Done.
And much the same as speedtest.net.
Although my question remains, why would my initially high line profile have dropped down by 10mbps? Worth asking for a reset?
John
Message 5 of 6
DLM can't be reset on FTTC. Your throughput is fine for your connection.
What was your estimation when you took out the service?
JohnWinter
Message 6 of 6
Thanks for the advice so far. Not sure about the estimate, but the line profile just after install was near 40mbps and I was getting mid thirties d/l, and near 10 u/l - so does my speed dropping off like this represent an issue, or normal behaviour?
