Message 1 of 8
youtube streaming problems
Hi does anyone have wifi streaming issues with youtube constantly buffers on phones and tv doesnt matter if on 5 ghz or 2ghz turned wifi sync off and firewall plus upnp extra security still just as bad this is as worse as virgin media youtube buffering 74 down 18 up
7 REPLIES 7
Message 2 of 8
Re: youtube streaming problems
HH5 btw
Message 3 of 8
Try a different wireless channel, there is a choice of 13.
Make sure "smart setup" is disabled.
Try using an Ethernet cable instead, to prove whether it is a wireless problem.
Message 4 of 8
Thanks keith yer forgot to mention ive tried channel changing plus no one has 5ghz wifi except me and just tried ethernet now to tv still same very frustrating
Message 5 of 8
Have you run a BT Speedtest using an Ethernet cable, to prove whether you have a fault with your Infinity connection?
Message 6 of 8
Just done now everything seems fine
Message 7 of 8
Then I have no idea, it may just be network congestion. Try the BBC iPlayer, and see of that has the same problem.
Message 8 of 8
I will report back later and let you know thanks for your help so far.
