PaddyB
Moderator
Moderator
Message 441 of 883
Re: 2.4GHZ and 5GHZ Bands BT Smart Hub 2
Hi @PC1977,
Thank you for posting back. I can see that my colleague @StuartH picked up your case. If you reply to the PM he'll take a look at this for you.
Thanks,
Paddy
PaddyB
Moderator
Moderator
Message 442 of 883
Hi @sido,
I've sent you a Private Message with the details for how you can contact the Moderation team.
Thanks,
Paddy
Hophead666
Message 443 of 883
@PaddyB
Hi Paddy
Please can you send me details of how to get the firmware update as I cannot print unless I turn off the 5GHZ.
Cheers
John
PC1977
Message 444 of 883
Thanks Paddy
Rmcrook
Message 445 of 883
@PaddyB  - can I also get information on this fix?
Thank you.
OneManTagTeam
Message 446 of 883
Replied to PM. Hopefully the FW update will remedy this because having to use only 2.4GHZ sucks
Cova123
Message 447 of 883
Hi @PaddyB
I've had the firmware update now, and my devices all seem to be able to communicate across both the 2.4 and 5 bands. However, the only device that doesn't is my HP printer. The printer is only 4 months old, so I doubt it'll be the printer?
To print without resulting to a wired connection or emailing to the printer direct, I still need to switch one band off.
billybob99
Message 448 of 883
Thank you
rikthemix
Message 449 of 883
@B3NNYB0Y just to let you know, I had the firmware update on my Smart Hub 2 and now everything works as expected.
Lovel
Message 450 of 883
Paddy,
Would it be possible to arrange the latest firmware upgrade for my router?
