JohnC2
Moderator
Moderator
Message 561 of 886
Re: 2.4GHZ and 5GHZ Bands BT Smart Hub 2
Hi @MD7  sorry about that, my mistake, and it should be with you now.
@Captainwilko  I've also messaged you so you can get in touch with us.
cheers
John
Kaydy
Regular
Message 562 of 886
Thanks to the mods for their help. Printer now printing... off to try the Sonos speakers next.
Frustrating that we had to come through this route to get a fix, but glad that people were able to help (albeit not the tech support helpline!)
dcookster
Message 563 of 886
When does the new firmware get pushed? My wireless printer has been in its box for months, I reverted back to my old USB cabled one due to constant drop-outs.
JonTTD
Message 564 of 886
Hi @Kaydy
Out of interest when did you report your issue? How long did it take for a repair/response?
the nice BT fella quoted 3-5 days, I’ve got my fingers crossed! 😁
cheers
jd
StuartH
Moderator
Moderator
Message 565 of 886
Hi @dcookster
I can help with this I've sent you a private message asking for the details we need to help.
Cheers
Stuart
Andysedg58
Message 566 of 886
Okay I have had the update today - but the firmware version is the same v0.26.03.01286-BT I had before.
I thought there was a version after this that solved the problem.
paulday888
Message 567 of 886
I’ve responded to the private message but want to share with the group that since the updated firmware I am still experiencing issues with ring cameras and I now have a new issue in that my sky Q box now keeps dropping signal which impacts the main box and the mini. Is that feeds off of it. This is very frustrating, had zero problems before that dodgy mid April update
dcookster
Message 568 of 886
Did you that you've received the new firmware?
VeteranISPUser
Recognised Expert
Message 569 of 886
Hi @Andysedg58   Reboot your Router.
wilson1101
Message 570 of 886
Devices  connected to the 5 GHz band are not able to communicate with devices that are connected to the 2.4 GHz band and it appears the connections are being erroneously  isolated
