Steveee
Message 881 of 891
Re: 2.4GHZ and 5GHZ Bands BT Smart Hub 2
As you’re on a different broadband network BT Support can’t access to the router.
sasghar12345
Message 882 of 891
Oh well, what a waste of hardware!
Steveee
Message 883 of 891
@sasghar12345  I bought my SH2 router on eBay to replace a SH1 router. I wanted to put in the BT Disc to extend Wi-fi into my garden but keep the same SSID.
As I have BT broadband BT updated the firmware.
So you have a few options: give/loan to a friend on BT Internet or sell on eBay with advice it needs to be used on BT Broadband.
SRB
Message 884 of 891
I moved to FTTP last month, new smart hub was supplied . The inability to split the wifi has caused so many issues with devices in the house over the last month, that I've gone back to an old Hub 5.  (We don't use the Digital Voice line as BT couldn't port our old number, don't ask have wasted so much time over this issue, which made the landline of over 20 years redundant anyway.) Obviously this isn't an ideal option for everyone, but if you aren't bothered about the Digital Voice option, the older Hub works fine and does make connected life a lot easier.
marge61
Message 885 of 891
I have also reverted back to the old hub. The firmware upgrade initially solved our issues but we started getting problems again with connecting to old Chromecast/printer about 6 weeks ago. Does anyone know if anything changed then?
SRB
Message 886 of 891
Our printer was one of the main issues too - some devices could connect others couldn't "see" it. My Smart hub updated 17th September, but it had not solved the issue.
glani74
Message 887 of 891
Another user here has the same issues and is unable to connect smart plugs.
Could I get the firmware update too, please?
thank you
imjolly
Message 888 of 891
what is your current firmware version?
have you tried disabling the 5ghz network and then try connecting to 2.4ghz and once connected enable the 5ghz again
glani74
Message 889 of 891
Hi thanks for your reply,
Current firmwear is v0.30.01.08093-BT
I haven't tried disabling the 5ghz yet no, will try that now, thanks.
Annmarie
licquorice
Message 890 of 891
That is the latest firmware.
