PaddyB
Moderator
Moderator
Message 311 of 886
Re: 2.4GHZ and 5GHZ Bands BT Smart Hub 2
Hi @craftycooky@aurel@netlaw,
Thank you for posting. I'm sorry if you're experiencing the same issue as mentioned in this thread. If you send me your details, I'll be able to take a look at this for you.
I have sent you a private message with instructions on how to contact the team.  You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
Thanks,
Paddy
Chris_V
Message 312 of 886
@PaddyB  I have been experiencing the same issue. Please could you PM me details of how to resolve?
Many thanks.
PaddyB
Moderator
Moderator
Message 313 of 886
Hi @Chris_V,
Thank you for posting. I've sent you a PM with details on how you can contact the moderation team.
Thanks,
Paddy
N-Jineer
Message 314 of 886
After the last firmware update to my SH2 I've had to turn off the 5Ghz to re-enable communication between our smartphones and our Google Chromecasts. Prior to that update, I had no issues at all with SH2 allowing 2way communication between devices on 5Ghz and devices on 2.4Ghz.
Can I get the the fix please?
craw19
Message 315 of 886
Hi @NeilO @PaddyB
Experiencing the same issue - Sonos basically some expensive book ends and can barely print. Please send me the update.
OneManTagTeam
Message 316 of 886
Having the same issues as many others. Printer, Sync Box and many other smart things not working for the past week or so.
Can I get the update to fix this too please?
lifeonmars
Message 317 of 886
Same here, need the updated firmware  pushed again to me please so I can get another Smart Hub2 updated.
BenD
Message 318 of 886
Hi,
I am having issues with Airplay 2 - tv on 2.4ghz and laptop on 5ghz, when on the same network they're fine, when not airplay 2 does not work.
Please can I get a firmware update to assist me in this.
Ben
geoffreyconn
Message 319 of 886
Hi
Could I get the new firmware Please.
I spoke to BT Technical and they refused to acknowledge the problem
garethbradley
Message 320 of 886
@PaddyB I'm having the same issue. Would you be able to PM me with instructions, please?
Many thanks!
Gareth
