welshybhoy1967
Message 861 of 891
Re: 2.4GHZ and 5GHZ Bands BT Smart Hub 2
Thanks for the help 👍
welshybhoy1967
Message 862 of 891
Thanks 👍
MSW1
Message 863 of 891
Hi.
Any chance of the firmware link for Smart Hub 2.
Many thanks
licquorice
Message 864 of 891
There is no firmware link for any BT hub. Firmware updates are automatic, there is no manual facility to update BT hubs.
Donaine
Message 865 of 891
Hi there not sure if this still valid.  Can we be updated too please
PARKERTEK
Message 866 of 891
Your hub will automatically update itself
1Gobe
Message 867 of 891
Hi SeanD,
Same problem here, as well. Firmware version SG4B1000E020 updated 02/Apr/20. Can I please get v0.26.04.04227 or newer?
Ta,
1Gobe
VeteranISPUser
Recognised Expert
Message 868 of 891
Hi @1Gobe   SG4B1000E020 is for the Smart Hub (Home Hub 6). Your Router is not compatible with v0.27.06.04290 which is for the Smart Hub 2.
1Gobe
Message 869 of 891
@VeteranISPUser  you are correct. My bad. Have been using my old BT router, since with the SH2 I cannot use my Brother printer which only supports 2.4GHz. My devices usually connect to 5GHz and they cannot recognise the printer. Hence the need for the new firmware.
I'll connect the SH2 and come back with the firmware number.
VeteranISPUser
Recognised Expert
Message 870 of 891
Hi @1Gobe   Your SH2 should update automatically if left connected for a few days.
