greenelement
Message 1 of 4
I can see this has been discussed quite alot. And there are workarounds but that is to do with turning off BTWhole Home WiFi and turning on only your 2.4 on your reuter, naming it the same as your WiFi on whole home and turning off 5ghz. Once you have set up your WiFi enabled gadgets you can go back to what you had before. My problem is I can't take the wall mounted heaters in the shed into the house!
Therefore I actually need the whole home discs to have 2.4ghz. is this possible BT please? Is see from the app that it recognises both
3 REPLIES 3
JohnC2
Moderator
Moderator
Message 2 of 4
Re: 2.4GHz
Hi @greenelement  thanks for posting and sorry you are having this issue with the WHW. It would be best to contact the WHW product helpdesk. You can call on 0808 100 6116 (Monday to Friday 9.00am to 5.30pm Saturday 9.00am to 2.00pm) or drop them an email to btconnectedhome@bt.com
cheers
John
greenelement
Message 3 of 4
Re: 2.4GHz
Thank you
greenelement
Message 4 of 4
Re: 2.4GHz
Sorted - Thank you BT..... 🙂
This is what you do -
Make sure you are connected to the BT WHW Disc on wifi.
Open up tab in browser and go to - Whole Home Wi-Fi - Wi-Fi (mybtdevice.home)
Enter admin password
Go to Set Up, then WIFI and then scroll down to 2.4GHz Device Setup Mode
Enable and then it turns off all 5GHz for 30 mins. And then switches back!
Very easy when you know how!!
