Message 1 of 6
Just bought a 4600 but i do not notice any difference in volume on the hand set or the base unit when i press amplify is anyone else experiencing this thanks
5 REPLIES 5
Message 2 of 6
Re: 4600
Hi, @Grayus I'm sorry about the delay getting back to you. The amplify button should boost the incoming speech volume on the handset when making or receiving a call and it will return to the default when the call finishes.
Have you tried increasing the default volume to level 5 to see if that makes it any better? I've included a link to the full user guide where it shows you how to adjust the volume settings.
Neil
Message 3 of 6
Re: 4600
Hi how do I redial on my bt 4600 as there is no redial button thanx
Message 4 of 6
Re: 4600
Hi @Grayus welcome to the community and thanks for posting. Page 36 on the BT4600 user guide explains how you can redial.
Neil
Message 5 of 6
Re: 4600
Thanks M8 must have had a senior moment as I read the book and missed it, still a redial button would have made more sense and ease .
Message 6 of 6
Re: 4600
@Grayus no problem, there's a lot of info in there so it is easy to miss.
Neil
