mark238
Message 1 of 3
4G Mini Hub
Hello All,
My internet is down with a PPPoE issue and after much difficulty of getting BT to agree for an engineer to come out, because I don’t have a HomeHub they are sending me a 4G Hub to keep me connected, also an engineer early next week after speaking with a very helpful and clever guy in the Newcastle office who understood the issue I was explaining. He deserves a promotion Danny I think his name was.
Does anyone know if I plug the device into my router it will act Share the WAN over USB. I know my router is capable of this but I can’t find any information on the Hub if it’s standalone etc?
Kind Regards
Mark
2 REPLIES 2
Keith_Beddoe
Message 2 of 3
Re: 4G Mini Hub
@mark238
The mini hub only transmits a wifi signal, it has no LAN port.
https://www.bt.com/help/halo/getting-set-up/using-the-4g-mini-hub-for-halo-customers
"You can connect up to 20 wi-fi devices. You won't be able to connect devices that need wired access."
mark238
Message 3 of 3
Re: 4G Mini Hub
Thanks Keith,
I assume setting the router to bridged mode to save me messing on and connecting all my devices might work, so I’ll give this a try instead.
Kind Regards
Mark
