Message 1 of 2
4G Mini Hub
Does anyone know if the BT 4G mini hub is or can be activated during a power cut or is it solely for BT faults?
Thanks in advance
Martin
1 REPLY 1
Message 2 of 2
Re: 4G Mini Hub
Hi @Muffer_2 thanks for posting, the 4G mini Hub will only be activated if there is a fault with your BT broadband.
Neil
