midlife
Message 1 of 12
4th whole disc missing from app
Hi
I have had our 4th disc linked to our 3rd disc with ethernet cable so I can have it set up some distance from the other three. However the 4th disc does not show on the BT wholehome app on the phone. How do I get it to show? I would like to set that 4th disc with a guest password so think I need it showing.
Graham
11 REPLIES 11
albertj
Message 2 of 12
Re: 4th whole disc missing from app
I assume the disk works, as in you're able to get Wi-Fi using it?
Please press the thumbs up if you found my response useful and mark it as a solution if I resolved your query.
BT Devices Expert
BT Devices Expert
Message 3 of 12
Hi @midlife
Which app version and operating system are you using? Can you see the 4th disc in the web interface (mybtdevice.home)
Dan-O
Device expertDanO
Show your appreciation!
Kudos”Kudos”
midlife
Message 4 of 12
Yes thanks
midlife
Message 5 of 12
Hi Dan O
I will check and get back to you
Thanks Graham
midlife
Message 6 of 12
Hi Dan-0
whoo never seen that before went into the mybtdevice.home and it shows the 4th disc and that it is connected by ethernet cable it is called wifi disc 0c.
the app is BT wholehome states current firmware as v1.02.08 build02 (cannot read anymore) and it is on my iPhone
Does this help?
still impressed with the mybtdevice thingy
Graham
lnajr02
Message 7 of 12
Hi What Device and Whole Home App version are you using?
midlife
Message 8 of 12
Hi Inajr02
How do I find which whole home app I am using as I go onto my iPhone I have got that it is app version 1.02.16 which I hope answers a part and the device is my iPhone i I have got that right. the whole hub is white sorry I don't understand
Graham
lnajr02
Message 9 of 12
If you IPhone is iOS 9 or above you should have app Version 3.3.4
you can find this by opening the Whole home app > Help > About the App.
Then just check all the discs have installed correctly using the App, they should have your selected name against each one.
If any are not listed with your selected name, using the Whole Home follow the App and the Add Another Disc process found in settings.
midlife
Message 10 of 12
thank you when I went onto help about the app on my iPhone the only info is what I provided, as said the 4th disc is not showing on the app so do I reset it to the smart hub and then replace to the wired link in my outbuilding. thanks
