Message 1 of 4
ARE ALL BT WIFI DISC COMPATIBLE WITH BT HOME HUB 2
Hello
Just wanted to ask are all BT WIFI DISC compatible with Home HUB 2 ? I been looking on Ebay & seen different versions .
I seen a black version that states its only compatible with Home HUB 2 or I'm wrong ?
I only need 1 to be connected upstairs .
Thanks waiting on replies first time using this forum.
Dan
3 REPLIES 3
Message 2 of 4
Re: ARE ALL BT WIFI DISC COMPATIBLE WITH BT HOME HUB 2
Black discs will only work with the SH2, white discs will work with any hub or third party router.
Message 3 of 4
Thank you so much for the quick reply this has cleared all up for me.
Message 4 of 4
@konyau100
Remember, if you are going to use the white discs, you need a minimum of two, as one always needs to be connected to the home hub.
