gslater
Newbie
Message 1 of 3
Access to BT Whole Home app
Hi
I am using the BT Whole Home App to restrict access to certain devices which works very well except that my son has now downloaded the app himself and can simply open it an turn off the restrictions. Is there any way to limit his access to the app?
Regards
Gavin
2 REPLIES 2
jrhop
Message 2 of 3
Re: Access to BT Whole Home app
Change the admin password?
BT Devices Expert
BT Devices Expert
Message 3 of 3
Hi @gslater
As jrhop has suggested, you should change the admin password to prevent him modifying the access controls. The app must have the correct admin password stored to access these settings.
Dan-O
