ShropshireLass53
Message 1 of 6
Activating voicemail on iPhone7
We have recently had new iPhone 7's through BT.  My husband's phone is not switching over to voicemail and he is missing calls and not getting messages.  How do I get his phone to go through to voicemail after so many rings or seconds.  I had the same phone at the same time and mine is fine.
Many thanks.
5 REPLIES 5
PaddyB
Moderator
Moderator
Message 2 of 6
Re: Activating voicemail on iPhone7
Hi @ShropshireLass53,
Thank you for posting. I'm sorry you're having problems activating voicemail on your Husband's phone.
If you take a look at How do I set up voicemail? you'll find a few suggestions that could help.
If the voicemail had been turned off by mistake dialing 15711 from the phone should turn it back on again.
PaddyB
ShropshireLass53
Message 3 of 6
Hello PaddyB
tried everything, still no joy, any other suggestions?
many thanks
Judith Johnson
Carlusha
Recognised Expert
Message 4 of 6
Have you checked Voicemail is activated on Hubby's phone   ....  or am I missing something and activation isn't required on the phone itself?
Open phone app, then voicemail icon, if empty, then it is not activated.
Matt-S
Moderator-Retired
Message 5 of 6
@ShropshireLass53,
If the above steps don't work then you will need to give our Mobile Team a call on 0800 800 150 and they will be able to help you out.
Matt
ShropshireLass53
Message 6 of 6
Thanks Matt. I will ring them tomorrow.
regards. Judith.
