Bennettboy
Message 1 of 3
Activation cost for second recordable box
I'm thinking of buying my own recordable box to replace the non recordable box supplied as a second box with the TV packages.
Has anybody done this themselves and if so how much was the activation of the second box?
2 REPLIES 2
NeilO
Moderator
Moderator
Message 2 of 3
Re: Activation cost for second recordable box
Hi @Bennettboy, thanks for posting, do you already have an extra box subscription? If you do there isn't an activation charge and you should be able to simply swap out the small zapper box for the new recordable box.
Bennettboy
Message 3 of 3
Yes I have a two box subscription, the little box is good but just want to be able to record without getting up and going downstairs to record on the other box. Thanks for assistance
