Message 1 of 4
Adding 3rd and 4th handsets to phone 8500 duo base
Hi,
The base station for my 8500 quad telephone set got destroyed by lightning. I have been offered a (private) replacement from a duo set. Will I be able to add the 3rd and 4th handsets?
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: Adding 3rd and 4th handsets to phone 8500 duo base
Yes, the base station remains the same for all packages, just the number of additional handsets changes to a maximum of four. So five in total.
Message 3 of 4
@anotherbigal
Welcome to this user forum.
This page should help.
https://www.bt.com/help/user-guides/phones/landline-phones/cordless-phones-with-answer-machine/bt850...
There is also a product helpdesk number.
You may have to reset the new base unit to factory default.
Message 4 of 4
Thank you for the confirmation. I was concerned as both base units specify how many handsets came with the sets when new and I didn't know if they wee somehow locked.
