SteveE1
Message 1 of 3
Adding 4th disc
I created a network using a 3-pack of disks. As soon as they all connected, they required a firmware update. Now I am trying to add a 4th disc, as soon as I turn it on, the app says I'm not connected to the WiFi, although I am. In other posts, it seems this happens due to a clash of firmware but how can I add my 4th disc? Any help appreciated!
2 REPLIES 2
JohnC2
Moderator
Moderator
Message 2 of 3
Re: Adding 4th disc
Hi @SteveE1 Check out message 3 on This Thread and try this it may help you get this fixed. Post back and let us know how you get on.
Cheers
John
SteveE1
Message 3 of 3
Re: Adding 4th disc
Thanks for the pointer, John. When I went back to adding the 4th disc, it connected straight away without the need for the factory reset. I guess it must have done an update in the interim. All working well now, devices switching seemlessly between the discs and full coverage around the house for the first time.
