Message 1 of 3
Adding third mini connector / powerline
Hi - I am having issues adding a third mini connector to my existing setup.
I have followed the instructions and the third connector flashes like expected but when i press add on the other connector nothing happens and no connection is made. The new connector just continues to flash.
Am i missing a step or doing something wrong?  the adapter works fine when plugged directly in the hub but i needed it for my office upstairs.
2 REPLIES 2
Message 2 of 3
Re: Adding third mini connector / powerline
Try adding the third unit whilst it is plugged in alongside one of the other two in a double socket. If it fails to work when you move it to where you want it to be, then you have a domestic wiring problem
Message 3 of 3
That seems to have done the job, the lights are occasionally flashing on and off but still getting internet,
Thank you  😊
