Message 1 of 3
Additional discs with BT Halo
is there a way to test if the the Disc is actually doing any good.  I received one, although I was promised three.  However the one I installed did not seem to make the signal any better in the room in question.  This is a room over our garage which has a brick wall between it and the router.
2 REPLIES 2
Expert
Message 2 of 3
Re: Additional discs with BT Halo
The BT App will have a wi-fi feature for complete wi-fi customers, it lets you map the ideal location for the disc, then if there are still areas without good wi-fi, you contact BT and they can use that data to determine if another disc or two are required.
Message 3 of 3
Open the MyBT app.
Click 'More' in the bottom right hand corner, a menu appears.
Click 'Your Wi-Fi Network' in the menu.
Your hub and disc(s) will appear with a connection report
