Flipflop96
Message 1 of 5
Additional handset compatibility
Hi,
just bought a BT4600 and wondered if my old BT4600 additional handset would work with it.
Thx
Tony L
4 REPLIES 4
Keith_Beddoe
Message 2 of 5
Re: Additional handset compatibility
As they are both the same phone model, you should be able to register the additional handset to your new base unit.
BrunoN
BT Devices Expert
BT Devices Expert
Message 3 of 5
@Flipflop96wrote:
Hi,
Thx
Tony L
Yes, if they're the same model, it'll work. You need to set the base station to pairing mode (usually long press on Page button; but check user guide). And on your additional handset, go to the menu to find the Register settings.
If you're asked for a PIN, it's usually 0000 (unless you've changed it previously).
Flipflop96
Message 4 of 5
Appreciate your help. Now have it working.
Tony L
Discom_ltd
Message 5 of 5
Hello,
For any additional handsets including  the BT4600 contact the BT Spares helpline on 0800 980 8999.
Regards,
Discount Communications Limited
