Phil_8049
Message 1 of 11
Admin password reset issues on BT Smarthub
HI
I went to change my admin password on my BT Smarthub, through the MyBT app.
On entering correct password, I keep getting incorrect password, try again.
Tried on a browser through the 192.168.1.254 IP address for hub manager, same error details again, together with a warning triangle, connection not secure (same on various browsers).
I have phoned BT, got through after 40 minutes, then was put on hold for a further 15 minutes, only to be informed that there is  nothing they can do, and will send out a new hub!
Has anyone had similar issues, its driving me mad.
Rgds
Phil
Tags (1)
10 REPLIES 10
imjolly
Message 2 of 11
Re: Admin password reset issues on BT Smarthub
are you connected to your home network?  are you entering the admin password not the wireless password
Phil_8049
Message 3 of 11
Hi
I'm entering admin password and am connected, no issues there.
imjolly
Message 4 of 11
I tried and looked through options on the app but could not find section to change admin password
Phil_8049
Message 5 of 11
That's correct, only option I have is to try and go through the IP option, which I tried and failed spectacularly.
I suppose when I get new hub, I'll just have to leave admin password as is, so I don't have to through all that b****x again 🙄
licquorice
Message 6 of 11
Have you tried a factory reset of the hub?
Phil_8049
Message 7 of 11
Hi, I did think of doing that thank you, but wondered if I needed to put the admin password in to access other hub details.
Anonymous
Not applicable
Message 8 of 11
Open the MyBT App
Tap 'More' (bottom right hand corner)
Tap 'Your Wi-Fi Network'
Tap on your hub.
Change Admin Password is in there
imjolly
Message 9 of 11
@Anonymous
Phil_8049
Message 10 of 11
I've done all that, but it wont let me in as password isn't being accepted!
