Message 11 of 14
Re: Another Router Locking Up during large file upload thread. SORRY.
I suspect that if you want a faster upload speed, you may have to use a different router which has a larger internal input buffer. The hardware in the home hubs has not really changed much over the years, but upload speeds have.
It may be worth trying an alternative to see if its any faster, as good wireless routers are not expensive.
BT TV Expert
BT TV Expert
Message 12 of 14
@tlmcloughlin
Thanks for confirming. The fix was not to the throttle network speed, the fix is to match upstream rates between the BT Hub and Openreach Modem.
I'd expect network upload speeds to be around 9/10Mbps.
Run a speedtest and see what you get!
Community ModeratorDarren
Show your appreciation!
Kudos”
I am a BT Employee and an expert on TV queries. I am here volunteering my own time to give advice, and help where I can with BTTV queries. Go here for more info.
Distinguished Guru
Message 13 of 14
DareenW. Is this something that end-users can do or does it require the intervention of Mods/tech support?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
BT TV Expert
BT TV Expert
Message 14 of 14
Hi @Devon_Dave
It does unfortunately require intervention from Mods/Tech Support at the moment purely just because of the level of access involved in providing a fix.
There is a fix identified for this issue so soon it will no longer be a problem, I can't comment on release dates so don't ask Smiley Happy
Kudos”
