ronhud
Newbie
Message 1 of 2
Answer machine audible notification
I have a BT3570 landline phone.  If the answer machine has recorded a message a light flashes but how can I get it to give a sound notification as well?
1 REPLY 1
Guru
Message 2 of 2
Re: Answer machine audible notification
Hi, if you type BT3570 into the help pages you will get the guides/instructions.
But here is the guide.
Stew
