john3650
Message 1 of 6
Assign band
How can I assign a printer to the 2.4 band only, and not have it on dual band?
Thank you
5 REPLIES 5
albertj
Recognised Expert
Message 2 of 6
Re: Assign band
Hi @john3650
Please could you post what router you use?
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
john3650
Message 3 of 6
Re: Assign band
BT Home Hub 6, sorry.
licquorice
Message 4 of 6
Re: Assign band
You can't 'assign' one device to a band. If you only want to use 2.4Ghz simply turn off 5Ghz
john3650
Message 5 of 6
Re: Assign band
OK, thank you for your help
albertj
Recognised Expert
Message 6 of 6
Re: Assign band
If you have a HH6, you can give the 5GHz a different name, and then connect your device to the 2.5GHz network.
Tags (1)
