Message 21 of 109
Re: Avast reports smarthub vulnerable to attack.
I also find it strange that of all the security software on the market only Avast is saying there is a problem bearing in mind this is new Avast software no long released on the Avast free version
maybe there is a problem but maybe it is just a false postive by Avast
Distinguished Guru
Message 22 of 109
I suggest reading the Avast forum thread :-
https://forum.avast.com/index.php?topic=215664.0
icepuffin
Message 23 of 109
Thank you for that, makes interesting reading , although it still indicates that that hubs need updating to DnsMasq software version 2.78. I was hoping that someone from BT would at least say that they are looking into it.
ljm
Expert
Message 24 of 109
Could one of the BT Moderators please reply to this thread please?................. just don't understand the delay in response to such an important issue.  Thanks.
Community Manager
Community Manager
Message 25 of 109
Hi Everyone,
Please excuse the delay in replying to this thread, I am very sorry.
We have highlighted these reports to our product team and they are currently looking into this.  I don't have an update just yet but the second I do, I will post back here.
Cheers
Sean
Community ManagerSeanD
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
ljm
Expert
Message 26 of 109
Thanks Sean for at least replying!.................. and look forward to your update on this matter asap.
icepuffin
Message 27 of 109
Yes, thank you for replying  and as iJm says , look forward to some sort of update.
icepuffin
Message 28 of 109
Sean D,
any response yet please.
ljm
Expert
Message 29 of 109
Why are we still chasing BT Moderators for an update to such an important thread???
Please advise Sean or any other Moderator.
V_Meldrew
Expert
Message 30 of 109
This sounds like scare tactics to me in order to convert users of the Avast free offering onto their paid for service. If you're really worried about it and are running Windows 10 then ditch Avast and go back to Windows defender, then get yourself a good VPN for less than the cost of a paid for AV
