sandyflett
Message 41 of 100
Re: Avast reports smarthub vulnerable to attack.
My hub had what I assume was an update a couple of days ago. It went off for a few minutes then came back on. But no info to say what had been happening. Maybe I should check my version status.
Message 42 of 100
the new hh6 firmware update ends B540
sandyflett
Message 43 of 100
Checked status. My version ends 522 done on 11 Jan 2018.
Log only gave event info for today, so no idea what it was doing the other day.
icepuffin
Message 44 of 100
mine is the same ending b522.
I suppose we just have to wait for the newer update to get downloaded as and when?
Message 45 of 100
only appears to have started in last week or so https://community.bt.com/t5/BT-Devices/Smart-Hub-latest-Firmware/m-p/1834929
thanks @Ribblelancs got wrong link before
Distinguished Expert
Message 46 of 100
@imjolly wrote:
only appears to have started in last week or so https://community.bt.com/t5/CL-Discussion-Board/Smarthub-New-Firmware-Update/m-p/1834481#M8203
I don’t think that icepuffin can access that link.
However, the B540 update is coming through.
Interesting that my own Norton came through with an obscure update, under the heading “Hub”. No doubt bt’ McAfee will also have the same updates. They all speak to each other.
DCglasgow
Message 47 of 100
Regarding the B540 update which is on its way,  but perhaps moreso the B522 update which others already have, can I ask please where you are seeing this info.  This is what I see on mine:
Firmware version:v0.09.05.11160-BT
Firmware updated:Thu Jan 18 21:44:24 2018
Message 48 of 100
@DCglasgow
that is not the hh6a firmware
DCglasgow
Message 49 of 100
I have the BT Smarthub, which Avast warns is vulnerable to attack.
Message 50 of 100
there is more than one variation of hh6
