Silver29
Message 51 of 109
Re: Avast reports smarthub vulnerable to attack.
I have just downloaded Avast and got the vulnerability message.  Sorry for stupidity, but with no technical knowledge, can someone tell me where I find my hub firmware version information?
icepuffin
Message 52 of 109
icepuffin
Message 53 of 109
Once you have typed in the 192....etc it will bring up the settings page, just click on 'status' and this will tell you the firmware number,.
They are supposed to be updating the firmware at some point,mine is still showing a vulnerability.
icepuffin
Message 54 of 109
Have just checked and my HUB 6 and it was last updated on 13th April, but I still have the vunerability message, so BT have not updated the DNS version during the update.
Silver29
Message 55 of 109
Thanks Icepuffin.  I would have never found my way in.  My hub shows as  ....B522 and says it was updated on 13 April 2018, so obviously must still be insecure.
ljm
Expert
Message 56 of 109
Mine was updated 22 April 2018 so I'm hoping all is secure now!
sandyflett
Message 57 of 109
So has AVAST stopped flagging up the vulnerability when it scans now?
ljm
Expert
Message 58 of 109
I'm not sure about that Beginner
ker585
Message 59 of 109
checked my hub yesterday, last updated on 15-Jan-2018, and avast still showing the issue.
ljm
Expert
Message 60 of 109
they've obviously not got round to updating your Hub firmware yet as the latest is April not January. You'll probably find all is well once you get the update.
