V_Meldrew
Expert
Message 71 of 109
Re: Avast reports smarthub vulnerable to attack.
@icepuffinwrote:
I did not aggressively rubbish your previous post. We have been trying to resolve this for months now and your answer was that it was "scare tactics" by Avast to get us to use the paid version, you offered no actual help on that occasion.
So why didn't you ask me to explain instead of getting abusive? I would have thought that what I put was perfectly clear then and even clearer now.
Have you read the article I posted a link too earlier today?
Message 72 of 109
@Silver29 wrote:
I am using the paid Avast which is showing the Hub vulnerability, so there are no scaremongering tactics to upgrade involved.
Sorry but not sure how just because the paid version shown same as free version that there is no scare tactics. It would have been more questionable if paid version had not shown same as free version
V_Meldrew
Expert
Message 73 of 109
The scare tactics I refer to are not intended to get people to switch to just any paid version, they are intended to scare people into buying the VPN service which is only available either with Avast Ultimate or as a paid for service on its own.
If you bought the Ultimate edition and are still having this problem then you should ask for your money back
Personally I wouldn't (didn't) go for the Avast VPN, there are more established services out there at a reasonable price.
icepuffin
Message 74 of 109
At no point was I " abusive"  I'm trying to sort this with others and all you could say was it was " scare tactics" to try and get us to pay for Avast. which I didn't take as helpful.
V_Meldrew
Expert
Message 75 of 109
Did you find the article I posted the link too earlier today helpful?
icepuffin
Message 76 of 109
Yes,  at least it helps to explain things better than your first post, but there is still a lack of response from BT over this issue .
V_Meldrew
Expert
Message 77 of 109
No argument there but I'm not sure what response you expect from BT after all this time.
You say you and a few others have been trying to sort this out but perhaps you could do more than bang your head against a brick wall (BT being the brick wall).
Personally, as you may have guessed, I'm not in the least bit worried about it but if you want to persue it further with the help of others on this community then here's a few suggestions.
Does this issue only apply to BT routers or does it also apply to 3rd party routers (e.g. TP-link).
If it only applies to BT routers, then does it only apply to certain types.
Does it also apply to those with BT routers who have opted out of BT WiFi.
Is anyone else, other than myself, using a HH6 with a VPN and if so do they get the same results as me when running Avast WiFi inspector with the VPN enabled.
Community Manager
Community Manager
Message 78 of 109
@bellrog wrote:
@SeanD  Dear Sean, please could you provide an update on this DnsMasq issue? Do I need to manually update the firmware in my BT Smart Hub or will BT be remotely patching these devices for its customers?
Hi @bellrog and everyone else,
I am so sorry for the delay in commenting on this thread.  I have spoken with our product team and can confirm that this vulnerability has been patched.
The most recent firmware that was released by BT (SG4B1000B540) has not updated the DNSMASQ version number however a patch was included which counteracts the vulnerability.  Therefore any customer on the new firmware is protected but Avast will still thrown up the warning message indicating you may be at risk because the DNSMASQ version number has remained the same.
There will be a future update coming which will address the DNSMASQ version number and once this has been applied you will no longer be presented with a warning message from Avast.  I dont have a concrete timescale on this but we hope to have this out to everyone in the next couple of months.
So to confirm, if you are running SG4B1000B540 then you are protected from the vulnerability but Avast will still show a warning message.  If you are still running an older firmware version then please make yourself known to the moderators and we can get your details to flash the new firmware to your hub.
Once again I am sorry for the delay in confirming what has actually taken place and I apologies for the confusion that still occurs.
Cheers
Sean
Community ManagerSeanD
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
DCglasgow
Message 79 of 109
Thanks for the update Sean.  My firmware is version v0.09.05.11160-BT, last updated 18 Jan 2018.
Silver29
Message 80 of 109
Thanks Sean. My Hub is still running version ending 522 last updated 13.4.18. Not sure where the 'contact link' here is to give you details. (Clicking on SeanD in the box at the end gives me an 'invalid parameters' message??)
