V_Meldrew
Recognised Expert
Message 81 of 109
Re: Avast reports smarthub vulnerable to attack.
@Silver29wrote:
Thanks Sean. My Hub is still running version ending 522 last updated 13.4.18. Not sure where the 'contact link' here is to give you details. (Clicking on SeanD in the box at the end gives me an 'invalid parameters' message??)
You need to sign in to get visibility of the "Message" button
Moderator
Moderator
Message 82 of 109
@Silver29 I've made the 'click here to contact the mods' link visible for you in my forum profile. You can find the link by clicking on my username.
Neil
Richard050
Message 83 of 109
Thank you BT, at long last clearing this issue up, just ran the avast scan again still showing there is as a problem but after cross checking the update number yes I am now protected and look forward to you sorting that other small problem out soon you pointed out.  I do feel BT was rather too slow to react to this and I hope you have made changes to inform us all quicker on any new issues which of course we all hope will not come around.
Silver29
Message 84 of 109
Thanks VMeldrum.  I was signed in but was getting an error message when clicking on Sean's name.  This has been corrected in Neil's post so that I can now click through his ID and have contacted him.
Silver29
Message 85 of 109
Sorry for typo in your name V Meldrew.   I do know someone called V Meldrum.
Silver29
Message 86 of 109
Thanks Neil.  Managed to click through this time and have left contact message.
V_Meldrew
Recognised Expert
Message 87 of 109
Hmm, V Meldrum - I like it
Maybe I'll change my username Smiley LOL
No worries, hope you get your problem sorted out.
icepuffin
Message 88 of 109
Good news..... light at the end of the tunnel.... but I do think that as the HUB 6 is supposed to be the 'flagship' of  BT  that they would have been on top of this a little earlier, it also shows that Avast was right in highlighting this issue, but thankfully resolved now.
Thank you.
Silver29
Message 89 of 109
Thanks Robbie from BT.  Sorry I missed your call earlier, but on checking my hub status, I see that it has been updated to the version ending 540.  I understand that although Avast is still showing a problem this has actually been corrected.
Thanks for help.
jyarwood28
Newbie
Message 90 of 109
My smart hub is running v0.07.05.0A13-BT .  Is this the correct version?
