Richard050
Message 91 of 109
Re: Avast reports smarthub vulnerable to attack.
Sorry error not been here for a while feel free to delete this.
Richard050
Message 92 of 109
Since May I have noticed the other minor issue still has not been sorted out by BT which causes my Avast WiFi inspector to inform me I am open to attack.  Yes I did get the May update by BT and as pointed out by BT the minor issue will be looked into, two months on and..Still waiting.
Falkie
Message 93 of 109
Yes, I also wonder if the small fix might come out soon. It is not just that the Avast warning is always a worry (even though the May/June patch may have fixed it), the problem is that it also affects a couple of Netgear extenders that I have on my network. They are apparently vulnerable also, but Netgear assure me that they are controlled by the router, so I wonder if the patch is as secure as we have been told. I am no expert at all, but my gut instinct seems to suggest that if the warning on the router was fixed then maybe my extenders would also be "fixed". Thanks in advance for any suggestions or help.
petrolhead276
Message 94 of 109
@SeanD
Thanks for your post explaioning that SG4B1000B540  is secure.
My BT hub is running SG4B1000B540 last updated 18-May-2018.
However you also stated that a later version will include the correct code that will allow the Avast software to correctly identify the threat has been patched and not throw up this error on each scan.
Can someone tell advsie customers if this " later fix" is now in place and how does one gets it flashed to their hub please.
icepuffin
Message 95 of 109
Sadly , no permanent fix yet, my system still shows it as vulnerable, to be honest I would have thought it would have been sorted by now.
vofsanity2
Recognised Expert
Message 96 of 109
@jyarwood28wrote:
My smart hub is running v0.07.05.0A13-BT .  Is this the correct version?
You have a Hub 5 and not a Hub 6. I suggest you raise a new thread.
philarktos67
Message 97 of 109
Hi
I have just recieved a 'new' BT Smart hub and got the Avast vulnerasbility warning. According to my status my firmware version is SG4B1000B522. Is the fix applied to this? If so why am I getting the Avast message?
imjolly
Message 98 of 109
@philarktos67
that is old firmware and will probably update overnight in next few days to firmware ending 540
philarktos67
Message 99 of 109
Thanks. I will keep a check on it.
Patricia2
Message 100 of 109
We recently swithched to the latest Smart Hub 6 and are receiving the same Avast messages as reported by others. Prior to discovering this forum I attempted to communicate with BT via their "Chat" service and also by phone and nobody had any idea about the problem, despite the fact we're clearly not the only ones to have had this experience. I'm surprised that this has been going on since January and there is still no solution. We are running the latest firmware which apparently has been "fixed" but surely it shouldn't take this long to address the DNSMASQ problem. Doesn't give us a lot of confidence in BT
