Beckyfreaney19
Message 1 of 2
BT 2000
U just bought the BT 2000 monitor and I am wondering does anyone know why the screen goes black and stops after a few seconds??? I have to press the ok button to get the screen back on??
1 REPLY 1
BrunoN
BT Devices Expert
BT Devices Expert
Message 2 of 2
Re: BT 2000
Hi, you can change the timing of the screen going off in the menu.
Press Menu key, then go to the icon that looks like a clock. Instructions are in your user guide too.
Also note that when the screen is off you can still hear sound and also see the sound indicator with the LEDs. If sound is detected the screen will switch on automatically (there's a setting to do this in the menu too).
Hope this helps.
