rastan801
Message 1 of 2
BT 4600 compatibility with BT advanced Z handset
hi, does anyone know if the BT advanced 1Z handset will work with full features on BT 4600 base, thanks
1 REPLY 1
MurrayB
BT Devices Expert
BT Devices Expert
Message 2 of 2
Re: BT 4600 compatibility with BT advanced Z handset
Hi rastan801,
Although you will be able to register the BT Advanced handset to the BT4600 base, the only features that you will be able to use would be making and answering calls.  The other more complex features would not work.
Should you wish to use the BT4600's full functionality you will ideally need to register another BT4600 handset.
