Message 1 of 3
BT 8500 Handset Lost PIN and no BASE Unit
I have a single - BT 8500 Quad additional handset with charger stand but no main base unit and cannot reset the PIN in the menu
I tried a reset but this does not reset the PIN and I do not have the PIN from the previous user
I wanted to use this as a additional handset with my existing BT2700 Base Unit/Handset
When I try and register the 8500 to the 2700 the 8500 asks for a PIN which I do not have
I tried 0000 withot success
Appreciate any solutions - thanks
Tags (2)
2 REPLIES 2
Message 2 of 3
Re: BT 8500 Handset Lost PIN and no BASE Unit
did you try 1111 which appears to be the BT8500 default
Message 3 of 3
Thanks for reply -
no good tried 1111  0000 1234, 4321 and no success
Is there some way of reseting the PIN ?
