Ricardo999
Message 1 of 3
BT 8500
I have a BT 8500quad set that has gone defective.
I have bout a new set of BT 8500 quad set.
Is there any wat to transfer my Contacts from the old to the new set ?
2 REPLIES 2
JohnC2
Moderator
Moderator
Message 2 of 3
Re: BT 8500
Hi @Ricardo999, thanks for posting. I've had a look at the quick start guide on the BT8500 Help page and could not see a way to do this. You would be best to contact the product help desk to be sure. The email and phone contact details are on the help page link above.
cheers
John
Ricardo999
Message 3 of 3
Re: BT 8500
Thanks John, not found anything anywhere, so I better get typing  !!
