DrawMike12
Message 1 of 2
BT 8600 phone sets
After some 18 months the phones have developed a fault whereby sometimes when dialling out it starts ringing  then stops and after a pause a recorded voiice says we do not recognize the number you have dialled.  The same thing happens on speed dial but trying several times it eventually gets through.  Any suggestions please
1 REPLY 1
DavidCo
Expert
Message 2 of 2
Re: BT 8600 phone sets
I have had the 8600 for a while and can drag up memories.
The supplied rechargeable battery may need replacing, if it does not take much time to recharge or the battery charge indicator changes from almost empty to almost full when you drop it in the dock?
You may have a intermittent line fault?
