Message 1 of 5
BT Access Control - What is midnight?
Hi, really noddy question - the Access Control settings allow you to set start/stop times for devices in 15min increments. I've been trying to work out what BT defines as midnight, ie; 12:00am or 12:00pm. I've had mixed results hence the question. Anyone know?
Thanks, Julian
4 REPLIES 4
Message 2 of 5
Re: BT Access Control - What is midnight?
12am is Mid-Day. 12pm is Mid-Night
Message 3 of 5
Other way around
12:00am is midnight, 12:00pm is midday.
You have to remember that as soon as a clock says 12:00am the new day has started it's the morning.
Message 4 of 5
I took a peek at the National Physical Laboratory website for clarification, this is what I found; "There is no confusion when using the words 12 noon (or midday) and 12 midnight, although the use of 12 midnight can raise the question of 'which day?'. To avoid confusion in, for example, an insurance certificate, it is always better to use the 24-hour clock, when 12:00 is 12 noon and, for example, 24:00 Sunday or 00:00 Monday both mean 12 midnight Sunday/Monday. It is common in transport timetables to use 23:59 Sunday or 00:01 Monday (in this example), or 11:59 p.m. or 12:01 a.m., to further reduce confusion.
There are no standards established for the meaning of 12 a.m. and 12 p.m. It is often said that 12 a.m. Monday is midnight on Monday morning and 12 p.m. is midday. This puts all the times beginning with 12 and ending with a.m. in the same one-hour block, similarly with those ending with p.m. It can also be argued that by the time you have seen a clock showing 12:00 at mid-day it is already post meridiem, and similarly at midnight it is already ante meridiem. Times in the first hour of the day are sometimes given as, for example, 00:47 a.m., with 00:00 a.m. corresponding to midnight, but with a time twelve hours later given as 12:47 p.m.
Another convention sometimes used is that, since 12 noon is by definition neither ante meridiem (before noon) nor post meridiem (after noon), then 12 a.m. refers to midnight at the start of the specified day (00:00) and 12 p.m. to midnight at the end of that day (24:00). Given this ambiguity, the terms 12 a.m. and 12 p.m. should be avoided."
Now I remember why I always use the 24 hour clock 😆
Message 5 of 5
Maybe BT need to update their access control settings to reflect this!
