philayl1
Message 1 of 2
BT Advanced Home Phone
Hi, I have just purchased the BT Advanced home phone, the instructions say to turn off the handset press and hold the red button, this turns it off but it restarts almost immediately on it's own, am I doing it correctly and does anyone else have this issue?     Phil
1 REPLY 1
JohnC2
Moderator
Moderator
Message 2 of 2
Re: BT Advanced Home Phone
Hi @philayl1 welcome to the forum and thanks for posting.
Check out the Help section on the User guide and if that does not help you should give the Advanced phone product support team a call on 0800 145 6789.
Cheers
John
